Hi all, I have the 07 DC/LB 4x4. I was looking for the zerk fitting on the u-joints and found none :sosad: . I thought all the 4x4 Taco’s had them. How are the other 07 4-bys configured? Thanks in advance.
grease fittingsLou czar said:WTF are zerk fittings
ditto on all countsCheazyE said:My '07 4WD Access Cab has a total of 5 zerks at the u-joints. 3 rear, 2 front.
There is such a thing as u-joints without grease fittings. Perhaps not all of out trucks got the same u-joints.AAATACO said:Bump, double checked and so zerk fittings. Anyone else have this issue?
The prerunners and minis use zerk-less u-joints on the DS (from what I have read here). There is a thread here (if you wanna search for it) from about a year ago containing this discussion.voodoochile said:I've seen u-joints without them before, but I think if Toyota was going to start using them then they would print a revised maintenance guide at the same time.
Stranger things have happened, though.
No, I have seen plenty of them with no zerks. Sealed and lubed-for-life (the life of the u-joint, I guessJanster said:There is such a thing as u-joints without grease fittings.
