Oil Leak 1998 Camry, but where is it leaking from? Help please..(Includes Pics}
1 reading
26K views 25 replies 13 participants last post by  justinclevenger.1234
Let me start by saying, I know very little about cars. This is my second car, my first was a 1995 Dodge Neon.
What I have now is a 1998 Camry that I paid $700 for. I am a rather broke girl, unfortunately. ...So I don't have the funds to really fix this right now, or possibly ever.
This leak is costing us (me and my fiance} a half a quart of oil a day. The car it's self runs and drives fine...It just has this bad oil leak. The CEL is on but that has been confirmed a being due to the Catalytic Converter needing to be replaced, rear bank I believe or something like that...I live in Florida, so right now the cat converter is not a huge concern at this moment.
We just had an oil change done 3 weeks ago. 1 week after the oil change was when this bad leak began. I do not know if there is any correlation.
During the oil change we were informed the oil pan drain plug was stripped and they put a gasket in it for us but said we would "eventually need a new oil pan"
The oil leak is NOT coming from the oil pan drain plug, as you should be able to tell from the photos.
I got some photos as best I could. We don't have a car jack that we trust enough to actually get up under the car and really look for the leak source, so this is the best I could do.
Does this look like it's the rear main seal? I don't know what that is, or where that is, just heard it was expensive to repair.
The leak is up above the back side of the oil pan (but not actually the oil pan, but from somewhere higher up}, somewhere...as best as we can tell.
ANY help and advice and ideas GREATLY appreciated! Thank you.
#4 · (Edited)
Ok, the 4 cylinders have common leak areas.
1, Oil sump gasket
2, Valve cover gasket.
3, Oil pump spaghetti gasket.
We have 2 Camrys, both leaked oil from the oil pump spaghetti gasket. It is a very common cause of leaks on Camrys.
You may be able to slow the leak down by using some ATP AT-205 and use high mileage oil such as Maxlife. These slowed our leaks down.
However, my best guess is you need to change the oil pump gasket - which is part of a timing best change.
We don't here many reports of the rear main seal failing but it is possible.
#11 ·
I have used ATP AT-205. Pls try it once before going any further. At worst, you will lose 10 dollars.
Thank you. I am starting think it may just be better to sell it as a mechanics special next month. We are moving to California next month anyways. I am trying to figure out weather it is worth fixing and if not, weather I should sell it or sell it to one of those "we buy junk cars" places.
#16 ·
Its under the timing belt cover, you cant see it without removing it. If its leaking directly below the crankshaft pulley thats your problem.
As other have said, try AT 205 sealer before abandoning the car. It might slow it down a bit.
The oil pump seals should be about $400 to change at a shop,which includes a new timing belt and water pump.
#17 · (Edited)
If the car is leaking as much as you indicated, it would have a puddle of oil on the ground where you park the car. Where this puddle is located at relative to the car can help you find out where actually the oil is coming from or if it is burning through the engine because of harden valve seals or PCV system. Your picture shows oil around the engine but not enough to use up 1/2 Qt in one day. If it is leaking from the oil pump, the oil dipping on the ground would be closer to the right wheel area. Do you have any picture of the engine facing the front of the car?
#23 ·
I have a 95 Camry. It had a rear main leak, that leaked into the transmission thru a worn out input shaft leak. I couldn't figure out it for the longest time how the transmission oil kept turning the color of honey. I swapped out the engine with another, with new oil pump, water pump, Bearings and seals, and pan cover gaskets. You Guessed it, I Still Have an oil Leak burning on the exhaust pipe, the smell getting into the car. I'm losing 1.5 quarts of oil per tank of gas.
