Oil sensor location
10K views 11 replies 6 participants last post by  93celicaconv
Can any help me with this I cannot locate this sensor anywhere
It's a low pressure switch, not a sensor, at least on the 4A-FE. When the pressure is low it has continuity and the wire is grounded which makes the light come on. The down side of this is if the wire is disconnected, then the light will never come on. Everyone should check that it lights up when the key is first turned to ON.
I think you have a 2.5L 4-cylinder engine (not a 2.4L).
Are you asking about the oil pressure & temperature sensor, or the oil level sensor?
If one assumes the oil pressure & temperature sensor, see the attached diagram.
You might want to ask this question in the correct forum (the RAV4 forum, this is a 6th Gen Corolla forum).
