Hi, I have a 2001 Camry, 4 cyl, 5-speed manual that is throwing P0300 and P0304. I replaced the 1-4 coil pack with an OEM part and the code is still being thrown. There are 89,000 miles on the car.
Now, at idle, it SEEMS to be fine, i.e., it idles perfectly smooth. and, if i slowly depress the throttle and bring the RPMs up to 2000, 3000, 4000 is SEEMS to be fine.
To prove this to myself, i yanked the Cyl#4 wire, started the motor up, and sure enough, you could tell it was misfiring... it is all lumpy.
Putting the #4 wire back in, i restarted, and all is smooth. When I bring the idle up by hitting the throttle hard (rather than slowly), i can hear / feel the misfire.
I checked the wires, they look fine. I do not see any burn/meltedness to it, the connectors look shiny, etc.
I am starting to think this is not an ignition problem, but rather a fuel delivery issue. I would think if it was the fuel filter, I would be getting P0300 - P0304 inclusive. Seems to be sticking on cyl #4 as the issue.
What do you suggest for next steps? I am pondering the injectors, tried searching the forum for a "how-to" on this but could not find one.
thanks
-jc
Based on this, I am thinking it is not an ignii
thanks
-jc
