Well will keep you updated. Took it to local Toyota dealer this morning for full diagnostic. I have had a buddy help me who is a retired Toyota mechanic and he is stumped as well. We took the engine apart and everything inside looked clean with no burn marks. We are hoping it is something electrical. Don't think it is a dead cylinder as all the cylinders compression wise are within specs and we did a leak test and could not find any leaks. We had the computer tested last week and it checked out fine. This all started because my serpentine belt tensioner went bad. My buddy accidently took out the bolt that held the oil cooler line in and we saw it had a heli-coil installed. I know the part was a factory recall and the dealer must have stripped the bolt out when doing the recall repair. I know I did not do it as getting to it required removing the alternator, dropping the A/C and disconnecting the radiator. But the repair was done so long ago I can not prove the dealer did it so I was stuck. I was not mad at the time as the car has had a small oil leak that I never could figure out and was glad that I finally found it. We initially tried just JB weld to fix the leak but no luck. Oil was now gushing out. Well when we took it apart again we saw the head had a crack in it at the inlet for the oil cooler line where the banjo bolt went in. So I had no choice but to do a top end job and replace the heads with used ones. They were redone at a local machine shop. The car prior to all this had no issues and no check engine lights. So thus far I have put in new used heads, timing chain (chain, guides and tensioner), new water pump, new coils, new plugs, new fuel pump.
