Parking brake is not available - car will not start! Please help.
2 reading
47K views 27 replies 20 participants last post by  gigantor0
I'm stuck. My car, 2022 Highlander Hybrid, will not start. I've been loading it up for a trip. For my dads memorial service 2000 miles away. All loaded and ready to go. Car will not start.
It keeps telling me "Parking brake is not available".
I suspect it is low 12v battery. But I'm not sure. I've been using the power liftgate more often than normal, so maybe.
I've connected it to a battery charger. Hopefully that will fix it. But it has not so far.
I'm 90% sure the 12v system is not being properly charged during "normal" operation. So Hyhi 12v batteries have a short life time. But that is post for another day.
I was hoping to leave tomorrow. It is new years day. Nobody is open. My car will not start.
I hope a squirrel did not disable my car by chewing through a parking brake cable.
I'm open to any and all suggestions.
Thanks
Car did start after being charged for an hour. Thanks for your help. Still charging at 10 amps. But that is plugged into the house.
I'll leave it plugged into the house until I have to leave. I suspect it will get me there. But it makes me wonder. We carry around a pretty big battery. Is there a way to force that big battery to charge the little battery?
I think there is a catch 22. Can't use the big battery to charge the little battery. Until the car is "ready. ' The car is not ready until the little battery is ready. The little battery controls everything
#5 · (Edited)
Toyota hybrids are very careful to maintain a "medium" state of charge on the traction (big) battery. The only way the vehicle can recharge the 12V battery is by drawing from the traction battery. If the traction battery is allowed to excessively discharge it will be unable to "turn over" the engine. Now you are stranded until the vehicle can be brought in to a dealer to replenish the roughly 300V traction battery. It is better for the 12V battery to go dead than to deplete the traction battery.
1. The hybrid 12V battery does not have much reserve capacity. It can be depleted much sooner than a traditional "starter" battery.
2. A hybrid requires little current from the 12V battery to start the vehicle but does expect a solid 12 volts.
3. Because of #2 it is possible to "jump" a hybrid 12V battery using a pair of light gauge alligator clips and a fully charged lawn tractor, motorcycle, trolling motor, etc. 12V battery.
4. Best practice (assuming adequate ventilation) when drawing frequently from the 12V battery over a short period of time is to leave the vehicle in the "Ready" condition so the engine will start as/if needed to replenish the 12V battery. Caveat: Don't forget to turn the vehicle off when done!
See #4
The little battery controls everything.
Most certainly true.
The OP stated that he was going on a long trip (sorry for the loss of your father BTW) so if the battery is in good health then the hybrid drive system will have time to fully recharge the battery. The parking brake malfunction was just a symptom of the low battery. Simply put the big battery can't start the car because the vehicles electronics (including all the computers and relays) are 12V based. With a dead or weak 12V battery the computers can't come online and without the computers the car can't operate. The big battery is just to power the electric drive motors, start the engine and recharge the 12V battery.
My guess would be the frequent opening and closing of the lift gate while loading up drained the 12V battery.
The solution is above... charge your 12V battery in the back of the car. Hybrids only need for the 12V battery to power the various electronics on the car; the "big battery" (traction battery) is used to start the engine.
It sounds like it's not hard to kill the 12V battery by using any accessories (lights, radio) too long when the car is not in on/ready mode.
#14 · (Edited)
Welcome to the forum @joshisandi !
There is more than one way to jump a Hybrid 12 volt battery.
It can be done from the engine compartment.
Since this is the Highlander Hybrid forum, I don't have a Sienna to look at but I suspect the engine compartments are very similar.
Open the hood and remove the cover from the fuse block that is right above the driver's side front wheel. There is a red safety cover (circled in green, see below). Lift this cover and you should find a 12 volt battery positive (+) jumper clamp connection point. Find a good ground point on the engine block for a negative (-) jumper connection. You don't need much of a jumper battery to "boot up" a Toyota Hybrid. A decent lawn mower or motorcycle battery would probably work.
#16 · (Edited by Moderator)
Don’t open the driver door. Opening the driver door tells the brake line to prime and it tweaks. So you have to climb in and out the passenger to jump start it. Ridiculous. This happens occasionally to my 2021 Siena. I get dismissed every time I bring it in for this problem so I haven’t found a solution. They refused to replace the 12V but I’m pretty sure this is the problem. I am woman so they give me a lot of dismissive tone.
Otherwise if you jump it after entering the driver side it will jump it and lights will come inn but not turn completely on the ignition.
This post has been deleted
#19 ·
I had the very same failed 12v problem on my 21 Platinum a few months ago and discovered a couple of things. First I had little or no luck using the under hood fuse block jumper method. I think part of the problem was my Li-ion portable jumper and how it measures voltage before applying jump current. Using the under hood method also triggered a check engine light which I was able to reset by unplugging the big red wire you see on the left side of the fuse box where the jumper blade is located. Once plugged back in the check engine light was out. I ended up jumping the 12v directly but this was a hassle because you can't open the tailgate without 12v power. Very frustrating you have to crawl back there if you need to jump the 12v battery directly. I trickle charged the 12v to recover it enough for a normal start the next day. In the end the dealership agreed the 12v battery was failing and they replaced it under warranty. Of note they replaced the original AGM battery with a Toyota brand traditional flooded lead acid battery.
#22 ·
Seriously? I don't own a hybrid (conventional ICE Highlander here) but the hybrid 12V battery is mounted in the passenger compartment, right? That would seem to be very dangerous..... an AGM is sealed but a conventional flooded battery is not and will vent hydrogen and oxygen during charging. Hydrogen + oxygen + ignition source (like the brushes in a motor) = kaBOOM!
Paul
#20 ·
I also am having this issue. I’m dead in the water in my driveway… I left my RAV4 Prime plugged in while the car ran for about 15min or less. I’m getting the no parking brake error and the car won’t start, even though it was running whole charging… I don’t have anything to charge the 12v battery with… or to check it…
#28 ·
I have a 2023 High Hybrid Platinum & got stuck in a Costco parking lot as it would not start panel message "parking brake unavailable" No ignition, couldn't open rear to jump battery. so tow driver jumpstarted it from engine compartment area. Towed it to Toyota & got was told battery had 2 dead cells so all electronics went kaput. Service advisor said it's a known issue & the new HH's will get a better battery. My battery was changed from a 345 cca to a 540 cca Interstate battery. Important to note I haven't driven the car in a week...I read in the HH manual the battery can discharge when not driven. I have trickled charged (solar) my 2006 4Runner for years w/ no problems & wanna put a solar panel inside the rear bed next to the battery. I know the solar panel won't generate optimal output, but you don't need much when trickle charging. Anyone else trickle charge their Highlander w/ a solar panel?
