"Perfect Stop" Brand Pads - Anyone Using?
2.1K views 8 replies 5 participants last post by  EngineerBoo
Our mechanic swears by them. They're no more expensive than any of the premium pads. My kid and I put a set in his F150 a few mos ago, seem to be fine, minimal dust and smooth stops. Only drawback with them is that you can't go to a store ( online or brick store ) and buy them. Mechanic has to order them in for you.
Thanks in advance for your opinions.
Definitely not budget. For sale only to the trade.
Here are my thoughts.
I recently tried Advics brake pads and have no complaints. I'm also a fan of Akebono brake pads. I like their ASP brake pads over the regular line brake pads but both are great. If you do need to end up replacing rotors. I could be wrong but I believe Advics produces the rotors for Toyota. I got mine from the dealership's parts department but you could probably find them on RockAuto too. I made a post about brake pads and rotors if you have some time to check it out. Also, I think it's a good idea to personally change them between 3-4mm. I wouldn't keep them any longer than 3-4mm personally. It's not really safe after that point. Also, check your slide pins, make sure your caliper piston is working properly, make sure you applied lubrication properly, and as a reminder check your brake fluids level or if needed change your brake fluid if you're past due. I'll attach a link for the discount code for RockAuto's website you may have to click jump to the latest on the top right. Best of luck though.
Post: Brake Pads and Rotors | Toyota Nation Forum
RockAuto code : RockAuto Discount Code | Page 25 | Toyota Nation Forum
#9 ·
Glad you like them. On our newest Toyota's, I go with OEM rotors and pads from the dealer (they give a military discount) and I do the job myself...the price isn't really all that much more than what they sell at O'Reillys auto parts store.
The only after-market pads I've tried, and liked, are called Import Direct ceramic pads. I've installed these (always with new Bosch rotors) on 4-5 of my families older vehicles with good results and seem to last a good long time.
