Power inverter for Camry
1 reading
5.6K views 15 replies 7 participants last post by  myang
The manual says to limit the round power outlet in the center stack to 12vdc/10 amp (120 watt max), but the outlet is on a 15 amp circuit. However, I would like to buy an Energizer 150 watt pure sine wave inverter that would need the full 15 amp capacity of the circuit…could that potentially damage the electrical system?
If someone could suggest a 100 watt pure sine wave inverter, I would buy that instead, but I haven’t been able to find one (the 150 watt pure sine wave inverter mentioned above is the smallest one I’ve seen).
Here’s a pic of the manual page:
Extra info: I’m planning to run a motorized pump while on an extended road trip in the near future. The power requirements are AC Power: 100-240V - 50/60 Hertz, 0.5A, 12V DC - 25 Watts.
#15 · (Edited)
It's not rocket science to find a spare fuse position constant or key-on and add a fuse tap and your own wire. Car mfg's spec a fuse and that wire is sized for that fuse. They made the guy that thought of that a VP. He saved them $5 a car. I install a specialized type of aftermarket equipment in cars ( not radios and DVD) and I can tell you that Toyota is using CAT5 sized wire all over the car. We can't even use a red tap, it's too big for the wires, we have to solder.
Having said that 150W inverter is what it puts out max. It is using 200-250W to do it's job. A 25W pump, find a 100W sine wave inverter. And just nosey and curious, are you taking your aquarium on a road trip? Ok, seriously is this for a medical device? If yes you need to have a dedicated circuit with an auto reset circuit breaker hooked up to a main 12v supply wire. A good and free website to find wire info is The12volt.com It is a free wiring guide, as in where to find constant 12V or key on 12V for remote start and stereo. ( anyone know where to find Bulldog now?) I can look this up for you also on my company's install guide which is based on real world installs, if you want to run a dedicated line. And before anyone gets pissy about company info, a third of that content is from me.
#16 · (Edited)
I can’t find a 100W pure sine wave inverter; the smallest pure sine wave inverter I’ve seen is 150W. Do you know of any 100W pure sine wave inverters on the market that I can buy?
I’m going to take a long roadtrip with my wife and baby, so we need a way to run her Medela symphony breast pump every few hours at rest stops in the privacy of our car. I actually solved this problem already by buying an OEM 12V DC car adapter for the pump, but I think an inverter would be useful for any other device we might want to power as well.
