Dear Toyota Customer Relations,
I am writing to express a persistent brake issue with my 2022 Toyota Highlander XLE, purchased brand new.
The Issue:
Since approximately 15,000 miles, I have experienced a persistent shimmering sensation in the brake pedal during braking, regardless of braking intensity. As it progressed, we could begin to feel it slightly in the steering wheel. Initially I thought it was just tire wear, but it progressed. And I decided to take it to Toyota to diagnose the issue. Here is breakdown of the history:
Service History:
-April 22nd, 2023 (18,417 miles): Toyota diagnosed and replaced warped rear rotors free of charge. This did not fix the issue and I took it back a few days later.
-April 28th, 2023 (18,460 miles): Toyota diagnosed minor hot spots on the front rotors. I paid 50% of the cost for replacing the front rotors ($111.48). This initially fixed the issue and it drove like new. However, it came back after about 8,000 more miles.
-September 5th, 2023 (27,640 miles): Toyota identified run-out in the front rotors, replaced them free of charge. Again, this fixed the issue, but like before, and about 8-9000 miles later it returned at around 35,000 miles.
Frustrated by the recurring issue, I took the following additional steps, all at my own expense:
-Self-installed higher-quality rotors from Rock Auto (around 35,000 miles). Fixed the issue as before. But returned around 42,000 miles. At this point I thought it may be the original tires, somehow causing the issue. So I had them replaced.
-Purchased and installed four new Pirelli tires (May 31st, 2024, cost me over $1,000+). Unfortunately this did not fix the issue at all.
-Went to Toyota and purchased and self-installed brand-new OEM front rotors and pads with shims from (June 1st, 2024, cost me $372.24).
This is clearly not a case of normal wear and tear. My wife drives this vehicle to work. She does not brake hard, she does not drive fast. We don't live on a gravel road, we do not abuse our vehicles. There is clearly something wrong with our 2022 Toyota Highlander XLE.
As a first-time Toyota owner, I purchased this Highlander with the expectation of reliability. The ongoing brake problem has deeply impacted my confidence in Toyota's product and service.
Therefore, I request Toyota to investigate the root cause of this issue at no cost to me. A permanent solution is needed to ensure the safety and functionality of my vehicle.
Thank you.
The Issue:
Service History:
- This is the fifth set of rotors on the vehicle at 43,326 miles.
Thank you.
