Not a lot on the forum about this. Wondering if anyone's tackled this job recently and if you found an affordable pressing tool. I'd like to avoid taking the car (or even just the axle) to a shop.
Yes, same seller as well. It was in September of 2023. By the way, I had good customer service from that seller because I needed to replace one of the threaded long bolts/rods and I was able to purchase the rod from her (the lady who was the rep at that time) as a separate part. IIRC, she's based out of California USA.Was this the tool?
Yes, that needs to be replaced.I haven’t done it yet, but…
One of mine is cracked.
As for symptoms, I have whst feels like rear instability in heavy cross winds or when behind a semi. Hoping this fixes that. Just replaced shocks - which helped, but it’s still there.
At the time I got the bushings, RockAuto had only one option. It was the Mevotech "Supreme", not the Mevotech "regular grade" (which ironically costs slightly more than the "supreme" currently). Of the choices I currently see on Rock Auto, I'd go with the Delphi brand (but as I said, if I were to do this again I would go with OE Toyota bushings).…on the bushings that is. Rock Auto has a few options. If I don’t want to shell out for OE I’ll at least try to avoid brand you went with and found less than perfect.
None of the aftermarket bushings are all rubber.The bushings currently on the car, and presumably, the replacement ones you’d get from Toyota, look to be rubber AND metal - but the aftermarket ones from RockAuto look to be all rubber? Does it just look like that because it’s all painted the same color?
This is the rear axle carrier bushing we're talking about. See my video in post # 4 or the video in post #11. There are no control arms on the rear of the 1ZZ-FE Gen 9.Dang, if I'd seen this I would have saved the control arms from the car I stripped!
Yes it's a must, especially with the cheaper tool. In fact, I wouldn't use "a little". I put it on nice and heavy. Same for my single-action spring compressor.A little Never Sieze or grease on the threads of the pressing tool would sure prolong the life of the tool.
AutoZone is not going to have this particular tool. I'd be shocked if they did because it's too model-specific (only for Corolla, Camry, maybe a Sienna).did you check with Autozone to see if they loan the tool.
