After stumbling upon this DIY I have been investigating and looking up the required parts.
I have also found two other sources of information on "adding CC" to, in my case, a 2007 Corolla CE Manual trans.
The DIY here on TN covers disconnecting the airbag assembly connection wires. The other two sources, also user forums, either do not mention disconnecting the connections, OR adamantly say DO NOT DISCONNECT!!
I am wondering why the different instructions?? There is mention of "static buildup" and danger of the airbag going off, but if this is the case then one would expect the instruction to say "be sure to disconnect"
Anyone have knowledge about this and what is the RIGHT procedure??
