Hi,
there is squeal noise when in low speed either drive forward or backward (when apply the brake). forward has more noise. They brake pad still has plenty thickness (almost same as the new). The shim is still attached to the pad well , just the surface is not that smooth.
I notice the left/upper/inner clip seems to touch the rotor. I am thinking to replace them and see if it resolve the issue. Between these two choices, is it recommended to go with OEM? $40 seems to be expensive.
1) Disc Brake Anti-Rattle Clip Set (Front)
Part Number: 0494708030
$38.84
2)
BrakeBest Brake Hardware Kit
$10
Thank you!
2003 toyota Sienna Disc Brake Anti-Rattle Clip Set (Front). Pads, Suspension, Brakes - 0494708030 - Genuine toyota Part
Disc Brake Anti-Rattle Clip Set (Front). Pads, Suspension, Brakes. 2003 toyota Sienna. Genuine toyota Part - 0494708030 (04947-08030)
parts.toyota.com
2)
$10
Thank you!
