Replacing passenger CV axle seal. What is this spring and where does it go?
14K views 7 replies 3 participants last post by  konoplya
You are correct on the spring, but it wasn't a stupid question. The only stupid questions are those that are not asked! Glad you sorted it out. Cheers!
Reactions: csherrow78
You may need to remove the axle and seal (I know that's a PITA) and inspect the axle sealing surface and see how the new seal (you'll need a new one) fits over that surface. It's possible that the axle surface diameter is out of spec (if it's remanufactured) or that the seal's diameter is incorrect. Just for an example, I was rebuilding my Honda's 5-speed and I needed an input shaft seal. Every single parts supplier (AutoZone, O'Reilleys, NAPA, RockAuto, etc) had seals with a 27mm diameter opening in their databases. When I got it, I knew it wasn't going to seal on the shaft as it was just too big. I checked the factory seal's specs and it was 26mm! I ended up ordering one from Honda and problem solved. Cheers!
Reactions: Donald E George
