running on 3 cylinders
3K views 8 replies 5 participants last post by  ghost_ryder35
hey guys,
i have a little problem here. my car is only running on 3 cylinders (cylinder 4 is not working). i have taken out all my injectors, cleaned the out and swapped them around, swapped my plugleads around and tested them, and even cleaned and swapped my plugs around but still cylinder 4 is not working. if any1 else has had this problem, or has any ideas on how 2 fix it, any help will be appreciated. thanks
hey it turns out that i've burnt out a valve in cylinder #4. thanks 4 ur advice guys... now i just have 2 figure out whether to recondition the head, or get a new car
G
#9 ·
you can pick up a head dirt cheap dude, or replace the valve(valves). save the all-trac my man, you will regret getting rid of it.
