Hi All 👋 I've been lurking these forum for several years now and benefited from the experience here which I'm grateful for. I started from no knowledge to being able to make significant repairs to my 2005 Corolla because of this and many other forums. For this, I thank everyone here.
I've made many progressive repairs to the car. The car runs nice and smooth. However, a persistent issue I've had up until now is negative fuel trims. We're talking -20% for LTFT and near -20% for STFT.
MAF readings is about 2.2g at about 700 RPMs. MAF is new and OEM (Denso). Has been cleaned with MAF cleaner.
Oxygen sensor is new (OEM). It functions well when engine is warmed out and I'm driving. It is rich at idle (high voltages).
Fuel injectors had been replaced by second hand ones. I get the feeling my problem may stem from there. The only issue is that I had bad fuel trims before I installed these 2nd hand ones so.. it's hard to know.
I had installed a new fuel pump before but I didn't install a new fuel pump regulator at the time ☹. It was a pain to unplug the assembly so I don't look forward to that if that's the case
I will likely screen dump my OBD stats here tomorrow for reference.
Does anyone know what it could be and how I could diagnose it?
