Hi, so having 4age Blacktop 20v engine running rich (like very), what could I do to fix it?
I'm trying to restore an engine swap done by someone else while learning, so go easy on me 😅 Chassis is a 1989 Toyota Corolla SR-5
Diagnostic:
I started my car after 1 month sitting and it started fine, but idling wasn't very good. Exhaust fumes smelt a lot like fuel, spark plugs are black (despite cleaning them less than 50 miles ago) and engine stalled after 5 mins of idling.
1) I dont plan on fixing the problem 100%, but at least make it more reliable/better. I dont have cats so no o2 sensors, so I know I could add that to help the situation. I would like to know where the o2 sensor connector is, since my harness is cut at some places and try to wire myself the sensor. If someone could send a picture of where they connect it so I have a general idea of where to look, it would help me tremendously.
2) Furthermore, I do not think I have a IAC (yes I know) which could cause bad idling (and maybe not enough air entering the engine so running too rich?). Idk, just trying to find solutions.. (I'll have to double check)
3) At last, I have an aftermarket fuel cell wired to an inline fuel pump. Is it possible that a 1/2 inch feed line with a 3/4 inch return line will force fuel through injectors? I have new injectors (every O rings are there), but there seems to be a small leak into the cylinders when fuel pump is on (and not cranking engine).
Thanks for helping
Diagnostic:
Thanks for helping
