Shift Solenoid Problems
7.3K views 8 replies 6 participants last post by  pladue63
1998 Camry 4 cylinder with 215k miles for sale for $900. There's a problem with the automatic transmission shift solenoid(s), but the car reportedly shifts fine. I don't know how he knows this is the problem, but perhaps it's due to his check engine light being on and he scanned a code indicating shift solenoid?
Seller is trying to arrange time for a test drive.
Before today, I never even heard of a shift solenoid. Are there risk factors for causing a shift solenoid to fail, eg infrequent ATF fluid changes, or it is a normal wear item? If the latter, should they be changed at certain intervals and at what intervals?
Yes, there are OBD2 codes for shift solenoids. If there’s no drivability issues, then it might be the torque converter lockup solenoid.
Hard to say why they fail. Could be lack of fluid changes. It’s not so common that I’d replace them on a schedule like plugs.
Reactions: John Gi
It doesn’t.
The purpose of that lockup clutch is to eliminate torque converter slippage. It locks up at speeds higher than 45 MPH. So you should see an RPM drop of about 300 when it engages. If that solenoid is bad, it won’t lock up. That’s why most people won’t notice it’s not workin. It’ll cost you a bit of fuel mileage is all.
Reactions: John Gi
Shift solenoids on the A140E are very reliable...the few times I've seen codes the trans fluid was very old. High chance that swapping out a lot of the fluid will unstick them; not so with Shift Solenoid SL (the torque converter lockup solenoid). That one has the highest failure rate (and that's still absurdly low). It's mounted to the outside of the trans case, toward the front of the vehicle; just grab another from the junkyard and make sure to get the o-rings for it from the dealer.
As always read the codes to point yourself in the right direction. There is no generic "shift solenoid" code, there are specific codes for each solenoid.
Reactions: pladue63
Another thing that can cause weird shifting is burnt sensor wires. When an engine is swapped, the wiring can be disrupted, drop onto the EGR pipe, and burn through. This happened on two of the five I've owned. To check if the original engine is still there, check the tag located at the pan rail opposite the starter. It will have a VIN on it, if original, it matches the car.
