Bought this '92 manual in Colorado two weeks ago. Seemed to have had a lot of attention/care from previous owner who'd had it 6 years. No evidence of any starting issues when we got it and did all the 'usual' checks. We drove it home about 200 miles and used it a couple of times with absolutely normal starting/function.
The problem first exhibited itself in the morning (inside garage on a reasonable day) with a no-crank. I took off the (newish) battery terminal connectors and cleaned -them although they did not look bad at all. Tested the battery - normal. When I tried to reconnect the neg. terminal after the pos., it sparked in an EXTREME way. I then noticed the 100A fuse (blue) next to the battery was blown. I bought a replacement and bolted it in. The same story with my attempt to reconnect the battery.
As the 100A fuse said alternator, I disconnected all three leads to it. Same story.
I disconnected the two leads from the starter - same deal.
I removed the rear cover inside the hatch and inspected the wires; I did not see anything worn or burnt.
I was unable to disconnect wires at the AC compressor so did not test there.
