Hello everybody !
I've an issue with my camry, engine 3VZ-FE, manual transaxle, year 1995, ~185k miles. Before all, I'm from France, and this engine is very rare here, I'm sure mechanics don't know anything on it. Sorry for my langage, too, I'll do my better.
When I start the engine, I have to keep my foot on the accelerator pedal, otherwise the engine stalls. The first time it happened, the engine was cold, it started as usual, but a few hundred meters later I felt like the engine wasn't responding as it should, and when I stopped along the sidewalk, the engine immediately stalled. I was able to park the car in my garage, and now I would like to repair it.
So I checked some parts as mentionned in the technical document :
This is where I am at now, and the engine still stalls. I feel like the cold injector is not working properly, could this explain the symptoms? Is there anything else I must know about this issue ?
Thank you for your patience and your help !
- the volume air flow meter : it works fine, values are OK.
- the IAC Valve circuit, with the step motor : I cleaned it, and it works fine too. I can open or close it as mentionned in the technical document.
- the intake air control valve, with the cold start injector. I cleaned it, it works when I apply vacuum with my mouth, but I didn't checked it with a vacuum gauge. I think it works fine, but I can try another intake air control valve (from another car) if you advise me.
- the throttle body, with the throttle position sensor : works as specified in the technical document. All is clean, each hole is free, vacuum can be generated.
