Hi all. Sorry for the longer post, but I would really like to clarify these questions once and for all. The mechanics around here don´t have a lot of experience with this car anyways, so you guys are my best bet.
I´ve mencioned this in another post, but thought it would be more effective to open a new post with the specific title, where I hope to get more answers.
So I´m getting codes B1811 & B1905. From reading on these dorums, B1811 often refers to a springclock failure, which is relatively easy to change and there are cheap parts available. On the other hand, there are few informations on the B1905 code. It is made up of the Center Airbag Sensor Assembly and Front Seat Outer Belt Right (RH). My BlueDriver lists this as a rare problem and the only reported fix is to replace Passenger Seat Belt Pretensioner Connector, which I´ve wiggled, un-plugged and plugged in a couple of times.
My questions being: do any of you have experience with these 2 codes? Could one be connected with the other? If B1811 is fixed with a new spiral cable, am I still stuck not knowing how to even diagnose B1905?
Both have the Center Airbag Sensor Assembly in the list, could that be a common issue here?
