Start up 2005 question
1.2K views 9 replies 4 participants last post by  Bcheney
My 2005 starts up with a roar ( 4.7l V8), then while backing out the drive way because its idling at around 2500 rpms, I back out my flat driveway with my foot on the break. I then put it drive and again my foot on the break i pull away from my home at idle. Which in this case is about 20 MPH. I live on a very narrow paved private road. I travel about 200 yards then the idle kicks down to normal and so called normal driving is done.
is this typical with the model age? My only other option is to let it run ( warm up for a minute or 2) before driving.
Discussion starter · #7 ·
Yes I do live in a cold state, southern Maine. it does seem to be excessive though having been a driver for over 40 years. This my first Toyota though and I noticed my mother camry kind of did the same thing, start with a roar and then settle down. None of my other cars really did it.
That said next time it in (needs an old change) Ill have them listen to it.
Discussion starter · #4 ·
High idle is normal for a cold engine during open loop warm up. 2500 seems a bit high, so I would clean the throttle body.
This is the procedure for a Corolla, so it is different as far as the actual hose removal. But the procedure for cleaning should he followed exactly:
http://www.toyotanation.com/forum/1...-diy-2005-2008-corolla-matrix-pontiac-vibe-dbw-throttle-body-cleaning-pics.html
Actually I was wrong it not 2500, it more like 1200-1800, enough where I can move along without touching the gas....But I think you link and information is useful, thanx
