starting occasionally
1.7K views 14 replies 6 participants last post by  Mike Gerber
My fellow TNers! After fixing the sputtering acceleration and weird idling issue I had, a new problem arises.
The camry was having some starting issues where it would take forever to turn over. It cranks and everything but it takes a long time to start. I bought a remanufactured starter and it worked for a little bit. After a couple of starts, the problem would be the same in that it would take awhile to turn over. I thought the starter was defective so I switched it out with another remanufactured starter. The same problem occurred.
I didn't have much time to do serious research so I went to kragen and ask them to test it out. They said the starter was fine and that I needed a better battery so I bought a new battery, went home and installed it the next morning hoping the problem would go away. I fired it up this morning but it took awhile to turn over.
I was stumped so I brought it into autozone for them to check the starter, battery and alternator since I didn't really trust kragen after this. The people are autozone said all 3 devices were fine.
Could it be an ignition problem or a bad spark plug/wires? Any advice would be greatly appreciated!
First of all cranking and turning over meant he same thing; the act of the starter rotating the engine until the engine fires and runs on it's own.
Second, we need to know what year car and what engine you have. 4 cylinder or V6? Generation 3 (1992-1996) cars are different from the generation 4 (1997-2001) cars. It would also be helpful to know how many miles are on the car and what if anything has been done to the car in the area of maintenance and repairs.
Mike
Hey mate,
Does the car run fine after you've actually turned it over successfully?
I don't know if it might be fuel related too... bad fuel filter, dodgy injectors etc.
As per previous posts, check the leads... they should spark. If they don't spark enough or at all, it could be the leads or distributor giving you grief too.
I'm sorry for not clearing things up:
The car is a 2001 Toyota Camry LE 4 cylinder with about 75,000 miles on it.
The car had an idle issue and occasional sputtering when accelerating. I cleaned the throttle body fully and that took car of that issue. I also seafoamed the car about 3 months prior and changed the oil and spark plugs a day afterwards. The car never had any problems after those two events.
I ordered a set of wires and plugs (correct ones) from sparkplugs.com so hopefully it will fix the issue when I receive them through UPS.
UPDATE!
the NGK plugs and wires came today and I just finished putting them in. Gapped it to 0.043 and torque the plugs at 13. Sadly to say, the same problem still exists.
I'm thinking of changing the fuel filter now. Any other advice as to what may be the problem? BTW, any brand recommendations for a fuel filter?
#8 · (Edited)
This should be done at night.
Once engine has started successfully,with a trouble light on, spray misted water in the vicinity of ignition wires and distributor..
Sometimes engine will immediately sputter. Leave engine running.
Turn light off and observe under the hood. Keep hands clear!!
Do you see arcing of ignition spark occuring anywhere?
