Thanks a million guys.
Couldn't find anything other than operational stuff in the car's manual. Took me a while to find the reset procedure, thought I'd share it.
Kinda garbled info but it got my sunroof workin' in my 09.
Thanks again,
Cheers
O021-03 Title:
SLIDING ROOF REPAIR TIPS
Models:
’02 – ’06 Camry
Technical Service
BULLETIN
November 12, 2003
TSB REVISION NOTICE:
December 12, 2005: 2006 model year has been added to Applicable Vehicles.
The reset procedure for TMMK-built models has been standardized so that Reset
Procedure 1 is no longer used when the negative (–) battery terminal is disconnected
and/or the “PWR No. 1” fuse is removed. Instead, Reset Procedure 3 will be used.
October 4, 2004: An additional Reset Procedure No. 4 has been added. Reset
Procedure No. 4 corrects the issue of the moon roof (sliding roof) glass assembly
reversing direction when the glass assembly makes contact with the wind deflector
during the “slide close” cycle. Introduction, Reset Procedure Applicability, and Repair
Tips sections have been revised. Applicable Vehicles now includes 2004 and 2005
model years.
All previous versions of this TSB should be discarded.
TSB UPDATE NOTICE:
The information contained in this TSB supercedes TSB No. BO002-03.
TSB No. BO002-03 is now obsolete and should be discarded.
The sliding roof system must be reset if the following occurs:
Pop noise when tilting up or down.
Glass tilt opening too high.
Does not stop in a fully closed and level position.
Glass assembly reverses direction when it contacts wind deflector during
The information in this bulletin supplements the sliding roof system reset information in
the 2002 – 2006 Camry Repair Manuals.
2002 – 2006 model year Camry vehicles.
OP CODE DESCRIPTION TIME OFP T1 T2
N/A Not Applicable to Warranty – – – –
Reset Sliding Roof Position
When the battery negative (–) terminal is disconnected or PWR No. 1 fuse is removed
due to the repair, the sliding roof position memory is erased. After reconnecting the
battery negative (–) terminal, make sure to reset the zero point. If the reset is not
performed, the sliding roof automatic operation may not function properly.
BODY
Introduction
Applicable
Vehicles
Warranty
Information
Repair
Procedure
SLIDING ROOF REPAIR TIPS – BO021-03 Revised November 12, 2003
Page 2 of 3
ORIGIN CONDITION
PROCEDURE
FOR RESET
VIN BEGINS
WITH
TMC built
CAMRY
When the negative (–) battery terminal is disconnected
When component parts of sliding roof are replaced
When the “PWR No. 1” fuse is removed
Reset 1
J
When the sliding roof does NOT stop at the fully closed
position even if the auto close switch is operated
Reset 2
TMMK
Wh t t f lidi f l d Reset 3
built
CAMRY
4
Glass assembly reverses direction when it contacts the
wind deflector on the “slide close” cycle
Reset 4
1. To reset the zero point for the sliding roof, push and hold the switch on the “TILT UP”
side until the sliding roof tilts all the way up and down a little.
2. Confirm “one-touch slide open and close” and “one-touch tilt up and down” functions
by pushing the switch briefly to the “SLIDE OPEN” and “TILT UP” sides.
NOTE:
See Repair Tips section on page 3.
1. Push and hold the switch on the “TILT UP/CLOSE” side until the sliding roof stops.
2. Continue to push and hold the switch on the “TILT UP/CLOSE” side for 10 seconds or
more. The sliding roof will move to the fully closed position.
3. Continue to push and hold the switch on the “TILT UP/CLOSE” side until the sliding
4. Confirm “one-touch slide open and close” and “one-touch tilt up and down“ functions
NOTE:
2. Release the switch, and within 5 seconds, re-push and hold the switch on the
“TILT UP/CLOSE” side.
The sliding roof will automatically move to full slide open and then reverse to the
closed position.
3. Release the switch.
Reset
Procedure
Applicability
Reset
Procedure 1
Reset
Procedure 2
Reset
Procedure 3
Page 3 of 3
4. Confirm “one-touch slide open and close” and “one-touch tilt up and down” functions
NOTE:
See Repair Tips section below.
1. Tap control switch to fully close moon roof.
2. Remove dome light assembly (forward of moon roof).
3. With battery connected and ignition “ON,” disconnect wire harness to moon roof ECU
and wait at least 15 seconds.
4. With ignition “ON,” reconnect wire harness to ECU.
5. With ignition “ON,” press and hold “TILT UP” button until glass assembly shudders
or makes a click sound. After the glass assembly shudders or clicks, release
“TILT UP” button.
NOTE:
If glass does not shudder or click, then ECU memory was not erased. Repeat steps 1
through 5 until unit shudders or clicks.
6. Within 5 seconds of releasing “TILT UP” button (end of step 5 above), press and hold
“TILT UP” button again. Glass assembly will go through 1 cycle (glass will tilt down,
slide to fully opened position, then slide to fully closed position).
7. As soon as the glass is fully closed, release “TILT UP” button. All functions are
now reset.
8. Reinstall dome light assembly.
The Repair Manual provides a reset procedure according to the plant where the vehicle
was produced. TMC Camry VIN starts with “J.” TMMK Camry VIN starts with “4.”
1. If the reset procedure does not remedy the condition, then reset again. Disconnect
the sliding roof harness from the sliding roof motor and wait for 3 – 5 minutes.
NOTE:
The sliding roof system must be reset each time the battery is disconnected.
2. If the glass parks in an over-flush or under-flush position with the roof:
A. Move the glass to the flush position by quickly tapping the switch.
B. Reset the system according to Repair Tips 1, 2, and 3 above.
Reset
Procedure 3
(Continued)
Reset
Procedure 4
Repair Tips
