Yes right hand drive.
I shall post more pics of the engine.....& any thing you would ask for like specs.
Thanks again Exage,
1. What’s the conclusion……is it wire or cable.........I had a feeling despite bein a med doc lol that it's drive by cable, although manufactured in 06.......does that make it simpler or more complex to install a supercharger?
2. I apologize………that is MAF sensor on the CAI pipe…….Piggy back, Greddy eManage, Apexi Power FC & SFC , & UNICHIP perform the same functions?
3. What are your personal views about SLR Ultimate performance chip…….to me looks like more of a scam…….SLR supposedly has similar functions to UNICHIP but the price is approx $70/ vs. $ 600/ for basic UNICHIP…..http://slrmotorsports.com/?
4. Flux with PDA is for personal engine testing…….where from can I buy it?
5. Higher pressure fuel pump & billet fuel rail makes sense.
6. In short what are ALL the components needed to install a Supercharger?
7. UNICHIP is strange, probably coz of its maps…….different for ones with & without turbo/superchargers……….again differ if both custom intake & exhaust are installed vs. stock………I think the gadget remains the same the difference is in the info stored in the chip, according to the stock vs. custom installs?
8. Where should I look for a super charger…….Are there any other reputable brands besides TRD or check eBay for a used one?
9. Why does UNICHIP only recommend K&N or Injen intakes…..cause their chip settings are according to them?
Yezinki.
Exage is it simpler to install & maintain a turbo or supercharger?
What are the main pros & cons of each?
What have you installed in your ride?
Yezinki.
This site shows that superchargers are still available.....which should I go with?
http://www.ineedtoyotaparts.com/index3.htm
1. Right hand drive explains why your car is drive by cable. It's not a North American spec Corolla... It is 100% drive by cable.
2. Yes that's correct. They perform the same function, what you listed are piggy back ECU programable units.
3. Never heard of it... If I ever decide to get a piggy back ECU I'm going with either a Apexi Power FC or Greddy e-Manage. Those are g
uarantied to work on the Corolla.
4. I assume online.
5. Yep!
6. Well it depends on how extreme. Supercharger, pulley, serpintine belt, fuel pump, fuel rail, larger injectors, piggy back ECU. These are the major components, there will be smaller ones that I missed. You'll need some time on the Dyno for tuning.
7. The chip is map tunable for different set ups. The maps will be all different for the different induction types.
8. I know that the Celica guys were using Greddy superchargers on the 1ZZ-FED. I don't see that supercharger on the Greddy site anymore. You could check e-Bay.
9. Doesn't matter which brand, any good CAI intake will do... like your Weapon R.
The supercharger will be easier. Both on install and engine maintence.
Well as posted above the supercharger is a easier install and cost less, and you'll get a noticable power increase with it.
The turbo will cost way more, however power out put isn't as limited with a turbo. Custom setups are very sick when they work out.
I haven't done anything performance wise to my ride except for the TRD brake pads.
On the wish list are: limited slip differential, 225/40-R18 wheel/tire set-up, black Injen CAI, Fidanza lightweight flywheel, performance clutch, Apexi Power FC, coilovers. Some of the goodies I want... most won't happen.
