Taco tunes harness
1 reading
4K views 14 replies 4 participants last post by  Cambam
Taco tunes has been super busy and not getting back to me. Anyone know for sure if this is the harness I need to plug and play from HU to amp and then back to original harness that was unplugged to plug this Taco tunes one in? If that makes any sense
#4 · (Edited)
Taco tunes has been super busy and not getting back to me. Anyone know for sure if this is the harness I need to plug and play from HU to amp and then back to original harness that was unplugged to plug this Taco tunes one in? If that makes any sense View attachment 383557
This is the one you need. It's the one Taco Tunes suggested. I used it for my Non-JBL system and works well.
This is the adapter I used in my install, it’s a ten pin connector. You’ll still have to modify the harness for your setup, these harness are intended to add a sub (it just taps into the front speaker signal and provides a pigtail to connect to a sub amplifier).
I'm gonna just get a harness for plug and play to a 4 channel amp to wire up the speakers. And use the RCA pre-out of that amp into the RCA ins of a mono sub amp. Unless you see an issue with that. Here's the RCA outs of 1 amp and here's the other amp I'll RCA in from this amp. So high level into 4channel amp then RCA out of that amp into the sub amp
