The Stage 3 Tercel camshaft is not good for Turbo use. We also do not have a specialized turbo camshaft yet. Luckily, the stock Tercel cam profile is extremely modest and it is well suited for turbo charging. The long stroke of the 3E-E engine also makes it very suitable for turbo charging.
The camshafts that we sell are indeed custom grinds. You will not find them anywhere else. I spent about 6 months determining the proper profile for our Stage 2. I've been testing it in my own car for several months. Our Stage 2 camshaft hasn't had, or caused a single problem as of 10,000 miles. The Stage 1 is the same camshaft with slightly less lift. The Stage 3 camshaft is the same camshaft with more duration. *It is not recommended for any car using the stock fuel injection.
The Stage 2 that we sell is actually bigger than a standard stage 2. It is unlike any other Stage 2 I've heard of. It has the most valve lift that you can put into it, but not too much duration. The cam performs miracles at lower RPM's. From 2500rpm's onward, the car is pulling hard and has no flat spots. You can literally lug the car at 1500rpm's and it pulls away smoothly from the stoplights. But make no mistake, this camshaft flat out screams. My Tercel can snap the rev limiter without any warning whatsoever. The engine is still accelerating when it hits the REV limiter.
Part of the reason that I have so much lower end performance is due to my custom headwork. I personally redesigned my 12 valve head by filling in some of the ports with high temperature filler material. Instead of increasing the size of my intake ports, I changed their profile to increase the air velocity. I didn't want to hurt driveability. I also cleaned up the combustion chamber and removed all the extra flashing around the valves. I had to port match the intake and the exhaust manifold as they were manufactured terribly. The 3E-E cylinder head really needs some help, but it does pay off. I was considering a swap to a 5EFE earlier, but now you couldn't pay me enough to get rid of my 3E-E. The power and extreme driveability is highly addicting.
I don't mind answering questions so feel free to write at
Ritalie_Racing@hotmail.com
Our camshafts come ready to use, and they do not require any break in period. They will last the life of your car and they will not go flat unless you run out of oil. Our Stage 2 camshaft is highly recommended, it is the biggest camshaft you can use in conjunction with stock Tercel fuel injection. You may be able to find someone else that sells a 3E-E camshaft, but they don't know what they are selling. With our (Stage 2) camshaft you can rest assured, it works excellently, we designed it. If you purchase one of our camshafts we will offer all of the technical advice that we can. We respond to all of our email.
www.redalertspokane.com
Checkout the online store.
