Hope you can help me. I have a 1991 Tercel with the 1.5L and 5 speed manual trans. It only has 208,000 miles on it. I have been doing my best to do some maintenance on it since buying it 6 months ago (plugs, tires, brakes, alignment). The problem I have is that at idle the car will stall once the electric fan kicks on. I have turned up the idle adjustment to compensate but, now it idles quite high. I tried to get the fuel filter replaced but, even the shop cannot get the lower nut loose to remove the filter. The PCV valve is in working order (makes noise when shaken and has vacuum) but, it seems to fit very loosely in the valve cover. I have cleaned the throttle body as well. Any advice you can give me would be appreciated. Thanks.
