testing or checking hydraulic motor mounts ?
5.2K views 6 replies 4 participants last post by  Hernandez
2008 with 213k..just bought it.
How does one inspect hyd mounts? I know how to check the old solid types.
How does one determine if they have collapsed, leaked or failed? Is there a way to measure the mount? But one would need to know the original height. Is there a certain "gap" or point to measure between the engine and frame?
Does any one have a side by side pic of a bad one they replaced and the new one next to it?
I've heard the OEM ones are very robust. I'd hate to just assume they are bad, order a set, remove the old ones only to find they are still perfectly fine.
BTW the dog bone is totally shot but that's not surprising.
I can see where it would be difficult to pinpoint the faulty one unless there are visual cues such as oil residues. I just replaced the dogbone on my 06 and I went back to OE from my local dealer. The aftermarket one only lasted a tad over 20k miles.
Put car in flat surface. Put it in park but release the parking brakes. Then go to the front of the car and rock it back and forth. The engine will start to sway back and forth. Look at each mount while doing this and you will see the one with the most movements.
I see it's been a while since this topic was discussed, but I just want to ask
has anyone here tried using a vacuum pump or gauge to test the hydraulic motor mounts?
I’ve been reading that some mounts can leak internally over time, which might not be visible but could affect performance. Would this method work for checking the integrity, or is there a better approach you all recommend?
#7 · (Edited)
If you've got excessive vibration and suspect the hydraulic motor mounts, I’d check their fluid-filled chamber for leaks first. A quick way is to visually inspect for any oily residue. If they’re worn out and need replacing, you might also want to assess your replacement pumps to ensure they’re in good working condition, as issues there could stress the new mounts prematurely. Simple checks often save a lot of hassle later.
