It wasn’t so long ago that washing the car meant getting a bucket, a hose and some soap, and then spending some serious time and energy to get every part of the car washed. Oops, missed a spot. Now you start over again.
Pressure washers make things easier, but you still have to get the soap and wax materials to the vehicle surface. Foam cannons take care of that, but not all foam cannons are created equal. That’s where the experts at MJJC come in. They have a complete line of foam cannons that make it easier than ever to wash a vehicle and the latest, the PRO V3.0, makes getting full coverage as simple as can be. Let us take a dive into MJJC’s foam cannon technology and see just what the art of foam really is.
Foaming
It seems simple. Water mixes with soap to create bubbles that get sprayed onto the vehicle. Where’s the art in that? Well it starts with having the right parts. There are multiple brands and each has its own flow rate, and connection, all of which go into how well the foam cannon will work. This is one of the areas where MJJC shines.
Each foam cannon is designed to work with the model of pressure washer you have. The connections fit perfectly, making it attach like a factory part and giving you complete functionality. In other words, plug in an MJJC Foam Cannon and get the most from your washer.
Pump Up The Volume
But it goes beyond the connection, and this is where the newest model, the PRO V3.0, shines. The bottle volume for the V3.0 is a whopping 1200ml, and the bottle is grooved to make it easier to hold onto. This gives you more volume for coverage between refills and makes it easier to get your vehicle covered in a short amount of time.
However, volume also has to do with which pressure washer you own, the amount of pressure it puts out, and which orifice is installed in your foam cannon. Each MJJC PRO V3.0 is shipped with a 1.25mm orifice installed. This is optimal for pressure washers producing between 1595 PSI and 2175 PSI. Other orifices are available as options. The orifice determines how much flow you ultimately have, but it is dependent upon your maximum pressure.
The PRO V3.0 also has an advantage of having replaceable filters and nozzles, giving you a longer usage life and options for how you apply your foam to your vehicle. With some sprayers, you are forced to replace the entire unit when the nozzles wear out, and you may not ever have options for the nozzle type. When you want pro-quality results, you need pro-quality equipment and that is what you get from MJJC.
Starting With Quality
When you step to a pro-level product like the Pro V3.0 Foam Cannon, you expect higher quality components. Stainless steel replaces other materials for added strength and corrosion resistance. This ensures you have a foam cannon that will last a long time.
One of the issues many have with foam cannons is leaking. After all, that is a lot of pressure to put on parts without huge surface areas. One area in particular that MJJC looked at was the cap for the bottle. The PRO V3.0 uses that latest leak-proof cap design to keep your bottle and cannon from leaking, which could lead to wasted soap and a mess for you to clean up. The new cap design prevents unwanted mess and loss, while keeping everything working like it should.
The PRO V3.0 Foam Cannon is guaranteed to work and if you follow the instructions, you will get a thick foam coverage with a density like shaving cream, perfect for getting your vehicle clean and shiny in no time. That is a guarantee right from MJJC.
Which Foam Cannon Is Best For You?
Starting off with a foam cannon from MJJC is already a step in the right direction. You will get the most options for coverage from the PRO V3.0 due to the nozzle options included with the product. The PRO V2.0 and S V3.0 are both constructed of brass, while the PRO V3.0 uses stainless steel and brass. They also have a maximum PSI rating of 3,600 PSI compared to the PRO V3.0’s max of 4,400 PSI.
The line of foam cannons from MJJC are all excellent units and choosing which one that fits your needs best comes down to things like how powerful your pressure washer is, which spray nozzles and coverage do you need, and what your overall budget is. You’re not going to make a wrong choice, but for the best results, you will want to strongly consider the PRO V3.0.
NOTE: This is sponsored content produced in partnership with MJJC
Foaming
Pump Up The Volume
