the dreaded camry 2.4l hesitation from stop
11K views 19 replies 7 participants last post by  rlee777
yessir...tried cleaning it first...didn't help much so i replaced with a new denso one this week. the signal cleaned up a bit but didn't really help the hesitation. i figured this was the answer but no luck so far. ill probably keep throwing parts at it lol throttle body is next on the list.
I have an 2008 hybrid Camry and I noticed my long term fuel trim was adding about 3% , I had put a new motor in it and it had some weird drivability issues so I took a piece of duct tape I cut the end so it conforms and lays flat in the air cleaner. It moved the long term to pulling less than one % and it drives perfect. Ultimately once my engine broke in, the air fuel stablized and I removed the tape after the long term started pulling 3%. Watch your fuel trims they can help give you an idea what’s going on.
