I searched and brought up many threads and learned a lot but am still confused about a few things:
Update:
OK, thanks to a suggestion by LetteringGuy, I found out there are only two bulbs which narrows me down to only one concern: It appears Daylight is same bulb as High. This said, since LEDs are not dimmable, my daylight running light will now run same brightness as high beam? This is ok? Not mods needed?
Original text:
How many headlight bulbs does my Highlander have, two or three? If three: a low beam (H11), High beam (9005), daytime running (9005)? I heard that my highlander might have only two bulbs--the daylight time running is actually the high beam just dimmed? Or am I misunderstanding...there are really two sep 9005s--one high, one daytime, just the same size? If so, the high and daytime are separate bulbs, the LED for the daytime would just run bright as I heard LEDs are not dimmable? Thanks. (it getting painted right now so I cant pop the hood to see how many bulbs there are)
Update:
Original text:
