Just had a timing belt job and it is like a newer car, I would say new but it is not like a 2017. The old timing belt looked OK so I can only attribute the improvement to eliminating belt stretch. I see that access plug to get to the tension pulley. I hope to reset the tension all I have to do is remove the spark plugs. If that is the case I will definitely try it at the 3 year mark. Before when I went to pass I could never get decent (any) acceleration. Now I can accelerate like a normal small car should.
Now I would like to know why resetting the tension is not part of the service interval chart. Why not list it as a recommended procedure at 3 years/40,000? They went to the trouble of putting an access plug there so why not at least mention to use it? I guess your car won't quit if you don't but the increase in performance, and I would assume gas mileage, is quite obvious.
If I reset the tension do I need to get in there and check the timing marks or will they just line up like when the belt was new? When done at the proper spot is the force of the spring supposed to match the resistance of the crankshaft pulley?
