Timing chain tensioner leaking or Timing chain cover?
1.2K views 2 replies 2 participants last post by  phivuu-2
I'm working on replacing old parts on the car and noticed oil behind the engine on passenger side. A quick google search gave me information that the tensioner is a common cause when it comes to oil leakage here. I cleaned up the mess and drove the car for a week and inspected it today. Seems to be a slow leak but I can't be sure if it's the tensioner or timing chain cover. What do you guys think? The bottom part of the tensioner and the bottom bolt is wet. The RTV next to it seems a bit wet but maybe that's oil from the tensioner? There's some oil below the tensioner to the left of it.
I cleaned it again and will inspect it in a day or so.
The leak must have been here for at least 4 years. I remember that the dealership mentioned it during a free inspection. No oil gets on the floor and I don't see any oil consumption. Level on the dip stick remains the same.
Start with replacing the o-ring for the timing chain tensioner. No need to replace the tensioner itself, but rather just the o-ring. It's cheap and easy. Here is a DIY on how to do it:
Fun Tip: The bore into which the timing chain tensioner inserts MUST be 100% clean of any varnish and/or debris. Use a solvent, like acetone, and a round brush, like this:
Fun Tip #2: Put some lube on the new o-ring before inserting the tensioner into the clean bore.
Fun Tip #3: Do not use any RTV/FIPG on the flange of the TC tensioner. The o-ring is what seals it, not anything else.
If you still have the leak after doing this, it might be the valve cover gasket or the timing cover gasket.
Here's a DIY for the valve cover gasket and also a DIY for the TC reseal:
#3 · (Edited)
I read the guide for timing cover reseal. Do I have to continue to support the engine with a floor jack when the side engine mount is removed? Should FIPG also be applied to the engine side where the head meets the block?
How did you clean the cover and engine side? The guide states to spray gasket remover on the engine side, but should that be avoided to not contaminate the timing chain and other internal parts? Razor blade and then spray it down with brake cleaner? Should I avoid using metal wire brush?
Cleaned up the leak today. Here's some pictures after a few hours. Tensioner is leaking for sure. But it also looks like there's a small leak coming from the seam between the head and block.
EDIT:
Cleaned up the oil and drove the car for 10 min and inspected it. It does leak from the seam next to the tensioner.
I also noticed old oil gunk on timing cover where all the pulleys are located. Is this just a leak from the tensioner?
I can see that there's old oil build up next to the tensioner on the top left front of the timing cover. Not sure if it went down towards the crankshaft.
I can't get a good picture of it but there's a lot of old oil gunk at the area I marked with a red circle between the belt tensioner and to the left of the crank pulley. It's also slightly above so maybe oil from TC tensioner? Picture underneath the crank pulley shows no oil.
Should I be careful when removing the crank shaft pulley to not mess up the timings, if I were to attempt to reseal the timing cover? Any tool that should be used to hold the pulley in place when removing/installing the bolt? I guess I want to prevent it from rotating?
