First clean throttle body if problem persists re-adjust TPS if problem still there then replace TPS but pull the ECU codes first to verify that code 11 is present telling you the TPS is bad.
To clean the throttle body remove the air intake hose and examine the intake and throttle body for excessive carbon build if found then buy a can of throttle body cleaner labeled "safe on oxygen sensors,TPS's and catalytic converters" and make sure your engine is fully warmed up prior to using as when the throttle body is hot it dissolves the carbon easily and quickly.The labels usually specify to park the vehicle at groung level (0 degrees,no inclination) and have the engine running but I disagree I instead park the vehicle on a hill facing down and shut the engine off and hold a rag below the lip of the throttle body and poor the stuff and use a tooth brush.
Normally you can re-adjust the TPS:
http://www.4crawler.com/4x4/CheapTricks/TPS/index.shtml
and not replace it but re-check you timing after you change it as it can retard your engine timing my as much as 10 degrees and cause your engine to overheat.This is the part # for the 85-87 22R-E:
TPS Toyota # 89452-20060
The part # stamped on my 85 4-Runner is Toyota # 89452-28010/30,ND # 198500-0100
At least one day before re-adjusting or replacing TPS spray both Philips screws with a deep penetrating lube several times:
1)PB Blaster
2)Liquid Wrench
3)Kroil Oil
4)Aero Kroil & Sili Kroil
5)Toyota Rust Penetrant or High Performance Penetrating lube
6)Rust Check
Any Public Library in your area would have the Factory service manual,Haynes,Chiltons,Mitchells,Bentley and Toyota repair books.
There is also free AutoZone service manuals at:
http://www1.autozone.com/servlet/UiBroker?ForwardPage=/az/repair_info/repair_guide/repair_guide.jsp
For scanned pages of factory service manuals for other engines:
http://www.brian894x4.com/Scannedmanual.html
http://www.showmesome.info/hilux/info/manuals/1KZ-TE
http://toyoefi.freeyellow.com/manual.html
http://www.grubinski.com/grubinski/manuals.html
http://www.hotrodder.com/kwkride/tech.html
http://www.autoshop101.com
http://www.mtv411.com/sitemap.htm
2003 Toyota Tacoma Factory Service Manual:
http://www.junglecode.com/toyota/tacoma/2003_fsm/
FSM (factory service manual)can be acquired in several ways:
Toyota Material Distribution Center
750 West Victoria St
Rancho Dominguez/Compton,CA 90220-5538
USA
Ph:1-800-622-2033 (outside CA)(M-F: 7-5 PST)
Ph:1-800-443-7656 (inside CA)
Ph:1-310-818-4630 (in or outside CA)
Speak to Beverly or Deloris
http://techinfo.toyota.com/public/main/mdc.html
http://www.4crawler.com/4x4/FSM.shtml
1)buy a used one off e-bay
2)some Toyota dealerships may give you one or sell it for $10-20 (used) as most Toyota dealerships don't repair many old Toyotas and no longer need the service manual
3)some public libraries sell their old books as they are not in demand any longer
4)some free buy & sell classified papers,websites and bulletin boards may have some used ones for sale
5)some junk yards may have one laying around
6)some Toyota specialty garages may have one laying around and no longer use it as the vehicle may be too old and those mechanics probably have so much experience that they could publish their own factory service manual with corrections and "real world repair tips"
7)if someone has the FSM maybe they could scan all of the pages and post it on a site for all of us to download or view.
Sidney
Repairs tv's,vcr's,home/car audio out of my home
E-mail:sidneybek@yahoo.com
Dartmouth,Nova Scotia
Canada
1985 Toyota 4-Runner,22R-E,W56,RN60LV-MSEK,rusted rear step/towing chrome bumper with 242 000 KM
:kingme: :canada:
