Hello Guys my left rear tire was low at about 28 psi and the rest were ranging from 30-33 Psi. So my tire pressure light was on because of the left rear tire that had low pressure
I put air in all four of my tires at the recommended level which is 35 Psi. And my tire pressure light disappeared as it should because All tires now had sufficient air.
I then drove my vehicle for about 20 miles and the tire pressure light came back on except this time all of the tire pressure readings that are displayed on the dashboard aren’t reading any number they are just blank spaces.
I’ve tried resetting my tire pressure system by pressing the set button in the glove department. The tire pressure light just keeps on blinking but doesn’t go away and the tire pressure readings have not appeared back again. I have attached a photo of what I am talking about.
any of you guys have any idea on what’s going on and how I can fix this problem ? Maybe I have a tire leaking air ? I suspect this Because my car is running a bit funny. It’s running slower than usual, it feels lazy. I’m having to press the gas pedal a bit more in order to get it up to speed.
