10. drain and refill coolant for cars with the Pink (100k mile) coolant.
9. any toyota fuel injector service (doesn't work), also it has been known to cause hydralock. if you insist on cleaning them use a BG product
8. a tire balance ever 6000 miles, tire balances are not nessisary unless your car vibrates as it goes down the road.
7. an ac refresher sevice, use lysol in your fresh air vents with the blower running
6. Light bulbs, you can get the same sylvania bulbs for like 25% less at autozone
5. an oil change, but don't go to the local quik lube either, bad things happen when the idiots that they hire to change your oil work on your car.
4. a brake flush. this is just an easy way for the tech to bleed your brakes it does nothing other wise.
3. a power steering flush, no real function whatsoever. you will have clean ps fluid.
2. a coolant flush, you can do this your self, and if you change your coolant at the normal service intervals you will never need this.
1. a trans flush, this is the biggest waste of money, drain and refill your trans and replace the pan gasket this will let all the fluid drain out for the most part. A trans flush can also wreak havok on an old transmission.
