Necro thread... but to help future searchers... from Paul's website, here are the specs for FRONT:
- Front caliper bracket bolts - 79 ft/lbs
- Front sliding pin bolts - 25 ft/lbs
- Should be the same for both North American made 4cyl and Non-TRD V6 as the front brake parts are the same per online parts fiche
My question - anyone have the specs on REAR w EPB? From parts fiche, the rear caliper brackets have different part numbers than the non-EPB rear caliper brackets
Rear brakes torque specs on V6
with electronic parking brake ?
- Caliper brackets - ??? (paul does not have this noted at all in his guide)
- Sliding pin bolts - ??? (paul has noted 25 ft/lbs for non-EPB rear)
From looking at older Camry model and Avalon specs, it seems the rear caliper bracket is typically less torque than front.
Anyone have a service manual on this with the specs? I'm not opposed to buying a day on TIS to confirm but figured I would check first. I've dug through all the threads I can find on here, and online in general, and have yet to see someone confirm V6 rear brakes w EPB torque specs. I suspect they would be similar to non-EPB, but I surely don't want to over-torque and bust a bolt or under-torque and perhaps lose a bolt on the road!
