There is a fantastic DIY post on transmission cooler line "flush" for the Corolla here.
I've read the online debates about never changing an old transmission fluid. And one counter is drain and fill is fine, just dont pressure flush them because the pressure might cause damage. Allegedly some/many shops are only recommending drain and fills these days.
I always thought the two options were drain from the drain plug, close the drain plug, and refill. Or to have a mechanic with an expensive machine pressure blast ATF into the system.
The above linked DIY post refers to the cooler line method as a "flush" but he's simply using the pressure of the idling car to slowly push fluid out of the cooler line, and refilling through the dip stick port.
It actually seems much easier to connect a tubing to the cooler line, then it does to jack up the car, get under it, and open the drain plug, and retorque it properly with a new crush washer. And cleaner because the tubing runs straight into the collection vessel.
The hardest part is trying to source the metal 5/16" tubing to go into the cooler line, I have no clue where to find that. But I think on my model Corolla, the cooler out-line is on top of the radiator so there's no weird contorting to access it. It seems like a no brainer to do it this way (if I can ever find the 5/16" metal tubing) compared to the drain plug method.
If you drain from the plug, you are only changing about 1/3 of the ATF, so you probably have to do it multiple times with driving between to get it all out. With the cooler line method it seems like it flows through all of the gears and once it comes out clean, you're good, once and done.
What do you guys think?
