Greetings. Proverbial long-time lurker, first-time poster. I hope to be able to eventually contribute as much useful info to the forum as I've gathered from it!
I have RTFMed and also carefully searched every archived post on this particular topic, though, and I am still at a loss to know how to proceed. Am hoping that the regulars here can line me up with correct guidance. You seem to be a top notch group.
Vehicle: '06 Highlander, V6 non-hybrid, 4WD. 103K miles. Serviced mainly at stealerships up till now with an occasional foray to Iffy Lube. I've been doing basic maint since roughly 95K when a family member handed the HL off to us. Ready to step up to more advanced maint tasks, including all of the transmission and driveline fluids. None of those have ever been changed so far as I can tell.
My understanding -- which may be deficient -- is that this generation of HL (and Lex RX) typically came with a re-usable metal-screened "oil strainer" internal to the transmission, rather than a disposable internal filter using fabric media. And that dealer techs would simply clean the screen and reinstall it if the pan had been removed.
Running a lookup via the Toyota corporate parts database, with the VIN for the vehicle, does now show a "TRANSMISSION FILTER", p/n 3533008010, which by appearances has filter media rather than a simple screen.
I gather from previous posts here that the disposable filter can also be distinguished by its having a ridged or corrugated metal shell, as distinct from the smooth metal shell of the screen-based oil strainer. The database image is of a ridged component.
My personal inclination if I drop the pan and find a strainer is to replace it with a bona fide filter. Big believer here in keeping fine particles of wear metals out of the moving parts (and the solenoids!).
But... does a filter, as opposed to a strainer screen, fit correctly on this vehicle? The Toyota database is cryptic on this point.
The "transmission filter" entry in the database is tagged with the words "From 200301 to 200509. From 200509 to 200612. From 200612 on."
Is this referring to VIN number ranges? The last six digits of the VIN? Because the vehicle's got a VIN well below the lowest number shown there.
I guess I also need to replace the "GASKET, OIL STRAINER", p/n 9008030077.
If any of you have successfully retrofitted a filter in place of an OE oil strainer, I'd be much indebted to you if you could relay your experiences, what worked, and/or what might not work. Thanks in advance!
