trying to get rims right
1.9K views 17 replies 5 participants last post by  blkdmnrcing
hey everyone,
so here is my dilema. my dad got some corolla rims for my camry. i bolted one up to make sure that it would bolt of ok and it does. now where the problem comes in is what size tire should i get, and if the rim will work ok on my car.
Thank you guys for the help.
Joe Portera
P.S. - if anyone knows the offset, then im sure you know if they would work. thanks again
#9 ·
lol, hey they were free, im not going to argue. my dad put a new set on for this guy, and he didnt want his old rims back, so i got them for free, just need tires
ok, I have 15x7 celica wheels on my 88 and they are VERY close to the rear struts, the offset is right and the spindles are centered in the wheels and the biggest tire i can run without rubbing is a 195-60-15, you are running a more narrow wheel so you should have some more clearance in the back. If you have alot more clearance or they hit, the offset is wrong and they wont be centered, any route, measure the diameter of the tire that belongs on the car and try not to get very far away from it
#11 ·
i bolted the rim up today and spun it around, everything was centered, they didnt wobble, or anything. there was a tire option for a 215/60-15, would that be just like yours? just alittle narrower on the sidewall
there is a tire size label on the drivers door jamb, measure that tire, and wobbling isnt good, but i meant be sure the spindle centerline and the wheel centerline intersect at the contact patch on the ground, it can be a little off and some cars are shipped that way, but if its real far apart, you will know it, easy way to check this is drive it onto smooth concrete and turn the wheels lock to lock, you should have a black spot or slight oval, if it is an arc, your setup is wrong
#13 ·
yea, well my dad is going to look at tires at work tomorrow, and im going to see if i cant round up some old tires for that size to slap on real quick and try. thank you all for the help, and if anyone has more ideas, let me know.
ok so i tried a 195/65-15 tire on the rim and here's what i got:
Front: if i cut the wheel all the way, it rubs on the inside front (where there is a bolt on hard plastic piece)
Rear: the tire comes with in centimeters of the strut. makes me alittle nervous when i saw it.
So i guess im asking this, would the 195/60-15 work, or should i find something with a lower profile?
