Universal Disable Auto Start/Stop Device DIY
1 reading
8.7K views 22 replies 12 participants last post by  9009RPM
I know @funman1 created a plug-n-play device for the 2017+ Highlander to disable start/stop, so if you want to easily install it, go ahead and purchase that here.
I'm here to share this info if you like to DIY. I bought a time delay relay device online. There are cheaper models but I bought this one because it has a case and looks decent. It's a universal device that you can use for a lot of things. It's also programmable and we can program it to simulate a button press as if pressing the start/stop button.
I used 18ga wires and crimped on male terminals. I didn't want to cut into the original wires so this was the next best thing. I plugged the terminals into the backside of the connector that has the pink and brown wires. Used a cable tie to wrap it just in case it slips out, but it's a tight fit in there. There's a good spot for the relay device to sit on, just use some double sided tape.
I've programmed the device to countdown from 10 seconds, then activate for 0.5 second. See video below. You'll hear a click from the relay activating. Not sure if funman1's device does that. You can always reactivate Start/Stop by pressing the dash button.
One great thing about a time delay relay is you can use it for ANY car that makes you push a button to disable Start/Stop. I bought it because this Highlander is not my personal car so I didn't want to spend too much money on it and I can easily remove it in the future for the next vehicle that has Start/Stop technology.
Fairly simple process and it'll take about an hour to get it up and running.
Nice work! Oddly enough, I posted same day, my finally getting around to installing funman1's module.
Well, I had ordered plugs that I thought would fit the plug on the Auto S/S stop about a year ago. Today, I finally decided to test it out and they fit perfectly. Took me an hour to wire everything up.
The product you linked is released after my installation as well as funman's device. Plus, I like doing it.
Plus, did you read the reviews? They're all about plumbing stuff...haha.
#20 ·
Hybrid doesn't have this stop/start feature because by design it's already stopping and starting the gas engine automatically based on your battery status, load, speed etc...
On the gas models, the feature comes in 2017+ HL models. Definitely not 2014-2016 models.
Sent from my SM-G973U1 using Tapatalk
