Does anyone know if there is a hidden USB the connects with the head unit? The Highlander does not have the 12.3” screen. When rearranging the tabs in the Source page it shows a USB1 and a USB2.
First rule of secret USB service port: don't ever talk about secret USB port. 🤣Wasn’t sure if there was a USB in the back of the head unit that naturally they wouldn’t talk about in the manual?
So you do not use AA then? You do not use any apps like maps or anything else on your phone. Just make calls. Do not get texts read to you. Do not dictate text messages. Do not use any audio functions on the phone. That right?I never connect the phone with a cord to the networked USB port for AA.....connects fine through Bluetooth with built in maps in the Nav leaving the one networked port free for music albums stored on the flash drive.
Myself I love change, but then I spent an entire career in IT which is nothing more than continual change of one sort or another.People learn how do to something one way, and then they want to stick with that way as much as possible.
I am trying to get a copy of said manual. Will appreciate a PDF version of it.The Navigation and Audio manual mentions that you won't have AA/CP and access to a USB stick at the same time. It's not so much a problem as an undesirable feature.
You're correct about the timeline around 2020. Right now, most Toyota models have an infotainment system called "Entune 3.0". It first appeared in 2018, and was available on most models by 2020. The previous infotainment system, "Entune 2.0", didn't support AA/CP. Entune 3.0 supports wired AA/CP. The new infotainment system, called "Toyota Audio Multimedia", is out on just a couple of models and it finally supports wireless AA/CP.
