Vacuum valve on bypass valve...
1.6K views 5 replies 3 participants last post by  4DMR2t
What does it do? I noticed mine was broken while putting the turbo and stuff back on after changing the hfh. It apparently is a one-way valve, but one of the outlet tubes was broken off and the valve doesn't work anyway(air goes both ways). I don't know if it was broken completely off or not while it was on the car, but it couldn't have been working like it's supposed to anyway. I got one kind of like it from autozone to use until the dearlership gets my new one in, and the car is running fine, I just want to know what it does. Thanks!
Andy.
I think he is talking about the check valve that connect to the lower chamber of the bpv. I know, because I also broke one of the nipples off mine one time.
You are correct in that it is a one-way valve. The stock bpv has 2 chambers. The vacuum line running from the intake manifold is "T"ed into 2 lines. One runs directly to the larger top chamber of the bpv, while the other runs through the check valve to the smaller lower chamber.
Under boost, the larger upper chamber produces more force and holds the bpv shut. When u let off the throttle, the upper chamber goes into vacuum, while the lower chamber holds pressure because of the check valve, resulting in the bpv snapping open.
Your simple autozone one-way valve should work just fine for now, but I don't know much about any long term problems/results from using an aftermarket valve.
