I'll try this again, maybe the way you're supposed to.
I have a 1993 pickup 4X4 22re with a loud knocking appearing to be coming from the exhaust side of the engine. Here is what I have done and please let me know what you're opinions are.
Started with a typical engine where the guy didn't replace the timing chain at 158,000 miles. Rubbed a hole in the cover, water in the oil, etc.
New head, Toyota main and rod bearings, new timing chain, guides, tensioner, rings, new cam, reused rocker arm assembly and rocker arms. Old exhaust manifold but remaining exhaust is new including cat. New 02 sensor. New PCV Valve. All new seals and gaskets of course. The cylinder walls spec'ed out great. Pistons spec'ed out good. Wrist pins good.
I have checked valve lash twice and is set at factory specs. I have gone though all the diagnostics in the factory service manual. Everything checks out. EGR system checks out good. Compression checks out good on all cylinders. I have listened for a long period of time and the noise appears to be coming from the exhaust manifold or the EGR tube above the manifold. Timing is set to factory specs. I'm getting no codes on the diagnostics. Vacuum system is in good order. The service manual says it could be the knock sensor, but does not show how to test it.
I need some help here. I hate to just start changing things. That's what are mechanics around this part of the world are doing. Change parts till one works. I'm getting a header but haven't received it yet.
Thanks in advance.
Thanks in advance.
