Rodge said:
I was under the impression that the cool water caused a pressure drop inside the differential which was what caused the air/water to suck in. So in turn, the differential breather, even though it's five feet off the differential is still going to suck shut. They are open by default because of the spring inside them.
But, now that I think of it more, the factory extensions have that 1 way valve/breather on them as well.
I see what you're saying. The cooling diff sucking in air is what pulls the breather shut is what you're thinking.
From the video it sounded like the valve opens as you drive, and closes when the diff is cool. (at least according to their reference about people waiting for the diff to cool before continuing deeper into the water)
So from the sounds of it the breather is normally closed. Driving for X amount of time heats up the diff fluids/air to increase pressure and open the valve. Then a water crossing (without waiting) cools the diffs so fast that
A.) the valve closes before pressure equalizes and water gets sucked in through the axle seals until pressure equalizes
-or-
B.) the valve sucks water in as before it closes because it's already under water before it closes.
Or maybe a little bit of both. The video seems to imply option A. is the problem.
I'm thinking the spring being out of the water (extended via the mod) would close slower if it closed at all. Figure that a hot material shrinks when cooled rapidly so a hot spring plunged under water would close the valve while a warm spring out of the water would not.
So does it come down to how fast and how much air is drawn in during the cooling? If it's not enough to suck the breather closed we are fine. Also, even if it did close the spring wouldn't it cause the hose used to extend the breathers to collapse slightly? The air in the hose (figure 5" of 1/4" fuel line hose) may be enough to equalize the pressure inside the diff? :dunno:
