Is there any benefit in waiting for a minute or two after a cold start?
Or can you drive right away and it has no difference at all?
Correct me if I am wrong. Atleast today morning after a real cold start (car had not been used for couple of days), I drove right away and when cold I thought it stayed longer in a certain gear before up-shifting....The auto transmission is programed to shift early, just like how a manual driver would when the engine is still cold.
I can tell you that until you engine fuel map moves from open loop to closed loop and you drive above 3K RPM...it is going to guzzle the fuel...
That would mean that if you want to try to squeeze out every last drop of mpg, it is better to let the engine warm up for a few minutes.At what rpm is it shifting above 3k? Cars do run rich on cold start to heat up the cat converter quickly for emissions.
I do not live in a extreme cold area. I totally agree with above and based on my attempt trying to warm at idle, I am inclined towards not warming it up on a cold start but just driving gently......The car will warm up much faster with a small load on the engine & burn off any condensation better. When idling it doesn't get warm enough ...
sorry, thats wrong information.1) Oil is thinner when cold(as in 0winter-20) so it flows to all parts of the engine faster
2) The mixture is enriched because gas doesn't atomize as well when cold so you need more for a smooth burn.
3) The transmission keeps the rpms high to warm up the transmission fluid. Warming up the oil is a side effect.
4) High idle on start is used to get the catalyst to light-off.
5) The engine is open loop until a certain temperature. It is running really rich(2) which drenches the o2 sensor in fuel making for a poor reading. After that it moves between open and closed loop based on load.
You should start driving about 30 seconds after starting to give the fluids a chance to get through the engine.
nevermind65;3730975I've had a couple of Toyotas now that hit 300k. I never let it warm up more than 15-30 seconds unless it is 0 degrees and I just want some heat in the car. At 300k miles said:I think you answered you're own question. If it was bad for the engine you wouldn't have made it this far.
The main advantage of synthetic is that it breaks down slower. You can get the same performance out of it but you have to change it more frequently.
