My wife's 2008 Highlander Hybrid has had wet carpet on the driver's side. Blew air through top front sunroof drains and up the tubes behind the rear wheels for the rear sunroof drains. Pulled rubber hole plugs from rocker panels behind front tires and blew air and verified that the seam weep points were open. Rear sunroof drains are open as is front passenger side, but driver's side front sunroof drain still isn't open. With the outer driver's side kick panel off, I can hear the sound of water gurgling when I blow air through the sunroof drain and water starts weeping out the hole for the fastener on the plastic housing of one of the electrical connectors mounted to the bottom of the pillar [EDIT: technically where the pillar extends to the bottom of the body side panel, not where the pillar meets the top of the body]. There is as large inset plastic block holding connectors above the lowest one that weeps water. Is this just a junction block or is there cabling behind it? Can I remove this block and use a cheap video borescope to look inside to see what's plugging the end of the drain and hopefully clear the clog?
