Hello everyone,
I just bought a 2022 hybrid highlander limited. My issue is with the second row A/C as the air flow and cold air are so weak compared to the third row, which is noticeably stronger and colder. I went to the maintenance 3 times, but it seems that they either don't know the reason or don't recognise it as a problem as it seems the problem also exists in other cars, so they assumed that this is the car design. Anyone who sits in the second row can notice the weak A/c, especially in this heat. Does anyone know the reason for this problem or do you have it in your car (so it could be the default)? I need to get back to the maintenance with a compelling evidence on my complaint. Do you also have the A/C diagram so I can check any loose or faulty ducts inside?
