Weather stripping, reducing wind noise
5.3K views 8 replies 2 participants last post by  elitemafia
So the weather stripping in my driver door is really bad, and their is an obnoxious whistling sound above 40mph. I can make it stop by wedging paper towels between tge door and the dash but it's annoying and I'd like to just fix it.
Should I just get oem? Are there any solid aftermarket options? How hard is the install? The oem weather stripping seems pretty pricey which is why I wonder if there's any other suggestions.
Had anyone here done this? Any diy guides? Do I need anything besides the rubber weather stripping for the install?
OEM.
Guide :
Ok. Buy OEM.
The way to install this.
Remove the sill protector and your driver's side kick panel.
289292
289293
Start from the corner of the of the door jamb on the B pillar.
289294
Then, the top of the A pillar.
289296
Then, the rounded corner at the mirror.
289295
Then, bottom corner of the fender.
289297
Then, bottom of the B pillar.
289298
Then, push every inch of the weatherstrip around the door jamb. Push into the sharp and rounded corners to ensure its seated.
#9 ·
I mean I may have to replace that molding you mentioned above as well, but I think I am going to try to just replace this first. Looks like it may be possible to do it without disassembling everything but I am not sure. There are a few clips I can see, will have to take a closer look later. I may just duct tape some foam to keep pressure between the dash and the door, as it seems to really quiet it down when I stuff paper towels in that gap.
