Wet Harness makes Door Locks Fail
1.5K views 1 reply 2 participants last post by  arabianobsession
2002 with 167,000 miles got parked for hours in a blinding rainstorm. Electric door locks failed to function normally. After drying for many days, functions returned to normal. The failures were:
Turning key in any door did not unlock the other doors.
Pressing 'Door Unlock' switches on inside of front doors did not function.
('Door Lock' switch functioned normally.)
When ignition switch was turned off, all doors were automatically locked.
The same failure happened again after driving in a light rain.
Is there some place where the harness or a connecter needs better water protection?
Finding a bad electrical connection is like finding a needle in a haystack. What I would recommend is finding a wiring diagram for a 2002 Rav and see if you can possibly trace the problem.
I had a similar issue in my old car, a Sunfire, after it would rain my parking/side marker lamps would be intermittent. But after a couple of days they would be fine. I never figured it out.
